ОптоЕлектроника
  Quote beTon Quote  Post ReplyReply #21 Posted: 11-Oct-2008 at 15:45
www.microvision.com
Microvision Pico Projector
Microdisplays: Coming Soon to an Eye Near You? - http://www.photonics.com/Article.aspx?AID=35002
it can be used to project vivid, full-color, high-resolution images that can range in size from 12 to 100 in..
The projected image has an infinite focus, so “whether it’s 12 inches or 6 feet away, it self-focuses
the company is also working to create eyewear that incorporates the technology.
Instead of being projected onto a surface, the image would be projected onto the wearer’s eye
Edited by beTon - 20-Mar-2010 at 13:31
  Quote beTon Quote  Post ReplyReply #22 Posted: 26-Oct-2008 at 17:18
иако сигурно во некоја сф книга е спомнато ова мислам дека на филм до сега го немам видено, најверојатно една од ретките работи што можат неподготвен да те изненадат, инаку примената нормално ќе биде во сите делови од нашиот живот, од градежништво(екстериер/ентериер), автомобилска индустрија, медицина, фото-леќи, дефинитивно секаде, може ќе го гледаме и на маса, чаши, тањири, вазни... и сето тоа и од практичен аспект, а и како симболика и естетика... а најпрво ќе го видиме како “eyewear“.
Sunglasses Developed with Adjustable Shade and Color - http://www.photonics.com/Article.aspx?AID=29481
Imagine a single pair of glasses with lenses that can be transparent or dark, and in shades of yellow, green or purple, all on command. A new lens with chameleon powers promises to dramatically improve sunglasses' function.
‘Smart’ lenses with chameleon’s powers are driven by electrochromic polymer.
The so-called “smart” eyewear relies on an electrochromic polymer in the lens that can modify the level of shading or that can change color when prompted by an electrical current. The glasses are powered by a tiny commercial cell battery with a standard electric capacity of ∼100 coulombs. Turning a button mounted on the frame of the glasses activates the battery and allows the user to control the tint and opacity. The researchers said that the lens can be tuned to a colored state in one second and back to a completely transparent state in two seconds.
After more than 100,000 cycles of switching the lens between a transparent and colored state, the researchers found that the device had a less than 6 percent change in transmission on the colored state and almost no change on the transparent state. They also found that the device could stay in a colored or transparent state without any charge for 30 days. A single battery powered thousands of transitions.
Organic molecules allowed the researchers to create colored lenses.
"In organic materials, the elements are simple but the structure is much more complicated," Xu said. "We can add more branches to this structure and tune in colors."
The prototype glasses change from dark blue to light blue. Xu and her colleagues have developed other adjustable lenses in red and yellow. In the future, they will layer sheets to create a range of colors in a single pair of shades.
'Smart' Sunglasses And Goggles Let Users Adjust Shade And Color
Edited by beTon - 20-Mar-2010 at 13:36
BlacK View Drop Down
  Quote BlacK Quote  Post ReplyReply #23 Posted: 05-Nov-2008 at 18:08
Eve prv pat i primena na tehnologija na hologrami od strana na CNN za vreme na objavuvanjeto na rezultatite.
Reporterkata e na 1000 kilometri od studioto vo sator vo koj e snimana od 35 kameri od razlicni agli i go formiraat hologramskiot prikaz vo studioto.
STAR WARS a? Big%20smileThumbs%20UpBig%20smilehttp://www.youtube.com/watch?v=66qtph_U6bM
  Quote lslcrew Quote  Post ReplyReply #24 Posted: 05-Nov-2008 at 18:10
Прееска го видов ова на вести на А1. Многу добра работа!
  Quote pbanks Quote  Post ReplyReply #25 Posted: 06-Nov-2008 at 12:26
Не сум сигурен дека се работи за холограм, колку што јас знам за таква технологија се потребни поспецифични услови. Милам дека се прави само на повеќеслоен видео сигнал кој се комбинира каде новинарката од одалечената локација зборува на плава позадина (како што прават прогноза на вести а потоја ја вадат од таму и ја лепат на готова позадина т.е. во овој случај сигналот од студио со Wolf Blitzer).
Во секој случај супер финта и ефект Cheers
Edited by pbanks - 06-Nov-2008 at 12:26
  Quote BlacK Quote  Post ReplyReply #26 Posted: 06-Nov-2008 at 14:03
Pred da se pojavi reporterkata najavija deka stanue zbor za prva upotreba na hologram vo zivo na CNN.Sega ne znam sto sve spagja pod definicija hologram ama mislim deka kamerata co bese od studio vrtese okolu "hologramot",kako bi go izvele toa so platnoto osven ako ne se vrti simultano so kamerata,ama toa mi izglea mn poprimitivno.Ne veruem deka bi se falele CNN a da ne e toa,toa.
  Quote lslcrew Quote  Post ReplyReply #27 Posted: 06-Nov-2008 at 14:14
Black колку што се сватив мислиш дека камерата у чикаго се вртела, а во исто време и кадарот во атланта па така се добива впечаток дека е уствари 3D. Мене не ми изгледаше дека е баш таква варка, пошто колку што приметив водителката не правеше толку мазни потези него баш имаше некое "сецкање" во преносот. Денеска 2D преносот не смее да си дозволи сецкање, и следува заклучок дека не е баш како што мислиш.
Мене ми изглда дека работи врз основа на некој вируелен 3D простор, а и на камерите кои снимаат и во чикаго и во атланта им се знае точната локација и агол во секој момент, па така се форумира и се исполнува тој 3D простор во "РАМ меморијата". Па после е лесно од еден простор да направиш копи пасте во друг и во тој другиот да се позиционираш во еден агол и да зрачиш слика.
  Quote BlacK Quote  Post ReplyReply #28 Posted: 06-Nov-2008 at 14:38
Ne e moe mislenje deka se vrtela kamerata, tuku posto pbanks rece deka ne mu se veruva deka e hologram,tuku ednostavno se lepi slika na platno kao na vremenska prognoza,zatoa dadov drugo razmisluvanje sto bi mozelo da bide ako ne bi bilo hologram.
  Quote lslcrew Quote  Post ReplyReply #29 Posted: 06-Nov-2008 at 14:48
Исто како на временска прогноза само 3D што не е многу тешко изводливо.
  Quote pbanks Quote  Post ReplyReply #30 Posted: 06-Nov-2008 at 14:51
види тоа со 35те камери повторно не е холограм, генерирањето на холограм се прави на друг начин во тоа ми е и поентата.
Значи холограм би било доколку новинарката се појавеше во студиото и Волф Блицер ја гледаше и разговараа. Колку што јас се информирав за холограмов на ЦНН Волф Блицер гледал во празно додека каналот со проекцијата на новинарката се лепел со каналот преку кој идела снимката од студиото. Значи не се работи за вистински холограм туку за on the air телевизиски трик, за симулација на холограм. Мене трикот сам по себе ми се допадна и воопшто не ми пречи што не е "вистински холограм".
Но поентата ми е дека CNN немаат апаратче како на Star Wars кое јас ќе можам да го купам и да го поставам во дневна соба и еве со тебе да разговарам а ти да излегуваш како холограм. Едноставно таква технологија уште не постои, холограмот се добива во специфични услови и неможе да се постигне во било кој бришан простор.
Еве еден од коментарите на кои налетав во врска со ова на ЦНН
"Blitzer didn't see a hologram at all. He was just staring into empty space, and the hologram was only visible to television viewers. In other words, it wasn't a hologram at all, but simply a 2D image superimposed onto the TV broadcast. What a waste of time!"
Edited by pbanks - 06-Nov-2008 at 14:52
  Quote BlacK Quote  Post ReplyReply #31 Posted: 06-Nov-2008 at 15:03
Ok.Ja padnav na trikot.Clown Mislev deka i voditelot moze da ja vidi Smile Ipak dobra fintaThumbs%20Up
  Quote beTon Quote  Post ReplyReply #32 Posted: 06-Nov-2008 at 18:00
иако доста луѓе на нет зборуваат за chroma-key мамка, сепак мислам дека се работи за холо,  но не е баш HG, но е налик HG т.е. holographic screeen(stereoscopic 3D images) технологија која уште од 2006 е на пазарот, но веќе денес е поусовршена што заради подобрените екрани кои се користат за да се постигне Pepper's Ghost ефектот, што заради ласерските проектори(првиот пост на странава). Холо екраните неможат да се приметат бидејќи се во темна околина, па ефектот делува ептен HG,  во моментов најизвикани компании на ова поле се Vizoo ,  Dimensional Studiosusion Eyeliner   , Holo FX и  EON Reality, иако целиот овој муабет го почна 3D Solar уште во ’04. еве неколку примери...
2008 -EonReality
2006 -DSMusionEyeliner
2006 -viZooC
2006 -DSME
Target's Holograms: The Innovation Angle
CNN’s holographic correspondent impresses hard-to-impress geeks
dejan View Drop Down
  Quote dejan Quote  Post ReplyReply #33 Posted: 15-Nov-2008 at 14:05
Ova kako vo toj film minority report http://www.engadget.com/2008/11/14/oblongs-g-speak-the-minority-report-os-brought-to-life/
  Quote beTon Quote  Post ReplyReply #34 Posted: 26-Jan-2009 at 19:00
се работи за Gesture Recognition односно манипулација на програми со помош на гестикулација, оваа технологија веќе некое време се усовршува, но на малку поинаков начин и за малку поинаква публика, односно досега се експериментираше и развиваше исклучиво како помошна алатка за глувонеми лица...
сепак тајфава буквално го репродуцирала ефектот од "малцински извештај" интересно е што се работи за сличен алгоритам како на  Multi-touch interface-от на Јeff Han што донекаде е блиску до вистината, само што тука се работи за месење воздух со datagloves ,  наместо свирење клавир по мултитач екранот Smile
www.oblong.com
Edited by beTon - 31-Oct-2016 at 20:37
  Quote Vladimir P Quote  Post ReplyReply #35 Posted: 22-Mar-2009 at 20:17
ТВ Сител денес, прв пат со холограм
  Quote La Linea Quote  Post ReplyReply #36 Posted: 22-Mar-2009 at 20:51
Previous ??
  Quote Vladimir P Quote  Post ReplyReply #37 Posted: 22-Mar-2009 at 21:00
Originally posted by La Linea
Previous ??
ХОЛОГРАМ НА СИТЕЛ
За прв пат на Балканот, во Отвореното студио на Сител Телевизија по повод изборите во Република Македонија, беше презентирана напредна технологија која се уште претставува предизвик за големите телевизии ширум светот.
Водителката Ивона Талевска ја најави својата колешка Славица Арсова, која холограмски се појави во студиото, а се наоѓаше пред Изборниот штаб на Нано Ружин.
Со ова, Сител Телевизија уште еднаш покажа дека е водечка телевизија не само во Македонија, туку и на Балканот.
http://www.sitel.com.mk/?ItemID=7BDB952B137A5241A3BDA4F759C18B3F
  Quote pbanks Quote  Post ReplyReply #38 Posted: 22-Mar-2009 at 21:04
Иста финта како CNN. Но работеле само со една камера. Добро го направиле но сепак... тоа не е холограм
  Quote Vladimir P Quote  Post ReplyReply #39 Posted: 22-Mar-2009 at 21:07
Е де де .. добро звучи, ние и американци xxx милиони LOL
  Quote pbanks Quote  Post ReplyReply #40 Posted: 22-Mar-2009 at 21:09
Еве линк до дискусијата кога излезе "холограмот" на CNN
http://www.build.com.mk/forum/forum_posts.asp?TID=333&PN=2
This page was generated in 0.373 seconds.
