Ведска математика
  Quote phenomenon Quote  Post ReplyReply #1 Topic: Ведска математика
    Posted: 23-Feb-2014 at 18:11
Интересни формули за брзо пресметување напамет
Tutorial 1
Use the formula ALL FROM 9 AND THE LAST FROM 10 to
perform instant subtractions.
For example 1000 - 357 = 643
We simply take each figure in 357 from 9 and the last figure from 10.
e
So the answer is 1000 - 357 = 643
Tutorial 2
Using VERTICALLY AND CROSSWISE you do
not need the multiplication tables beyond 5 X 5.
Suppose you need 8 x 7
8 is 2 below 10 and 7 is 3 below 10.
Think of it like this:
g
The answer is 56.
The diagram below shows how you get it.
h
Tutorial 3
The easy way to add and subtract fractions.
Use VERTICALLY AND CROSSWISE
to write the answer straight down!
k
Multiply crosswise and add to get the top of the answer:
2 x 5 = 10 and 1 x 3 = 3. Then 10 + 3 = 13.
The bottom of the fraction is just 3 x 5 = 15.
You multiply the bottom number together.
Tutorial 4
A quick way to square numbers that end in 5 using
the formula BY ONE MORE THAN THE ONE BEFORE.
752 = 5625
75² means 75 x 75.
The answer is in two parts: 56 and 25.
The last part is always 25.
The first part is the first number, 7, multiplied
by the number "one more", which is 8:
so 7 x 8 = 56
t
Similarly 852 = 7225 because 8 x 9 = 72.
http://vedicmath.50webs.com/tutorial1.html
Edited by phenomenon - 23-Feb-2014 at 18:49
  Quote gjoko Quote  Post ReplyReply #2 Posted: 23-Feb-2014 at 21:49
Имаше некој на нашите емисии(Тентов или некој сличен) кој ја објаснуваше оваа математика.Има фасцинатни работи за тоа
еве нешто слично
  Quote phenomenon Quote  Post ReplyReply #3 Posted: 24-Feb-2014 at 12:21
Зошто цифрите ги пишуваме онака како што ги пишуваме? Зошто еден е 1, а два е 2? Еве го одговорот:
http://mediaserver.fxstreet.com/Reports/54a5d70c-d1a2-46ed-baeb-39277c829542/lisson_20100602111201.jpg
This page was generated in 0.775 seconds.
