Технички импровизации
Category: Останати теми
Forum Name: Наука и технологија
Forum Discription:
URL: http://www.build.mk/forum/forum_posts.asp?TID=3008
Printed Date: 02-Nov-2025 at 10:16
Topic: Технички импровизации
Posted By: +Protagorist
Subject: Технички импровизации
Date Posted: 27-Feb-2014 at 01:51
кускатои, хакои и комшикапиџик иновации ...
shortcuts, hacks and backdoor inovations...
[tube]swvYZ-vp25c[/tube]
https://www.youtube.com/user/kikiriku200/videos - https://www.youtube.com/user/kikiriku200/videos
http://www.icedamremovalguys.com/learning-center/roof-snow-removal-101/ - http://www.icedamremovalguys.com/learning-center/roof-snow-removal-101/
[tube]D3aiqUMNOF8[/tube]
[tube]csqjGBzGyvA[/tube]
Date Posted: 27-Feb-2014 at 15:18
http://www.popularmechanics.com/home/improvement/electrical-plumbing/prevent-home-plumbing-nightmare - http://www.popularmechanics.com/home/improvement/electrical-plumbing/prevent-home-plumbing-nightmare
[tube]0BcwA8T4WPo[/tube]   [tube]BLfI2lGhtHQ[/tube]
Date Posted: 27-Feb-2014 at 22:11
[tube]YODdMwlXGcg[/tube]
hidraulicna pumpa za protocna voda od izvor il reka diy zastedata e od 300 evra pa nagore se do 3000 [ http://www.greenandcarter.com/main/product/prices.htm - 1 ]
http://www.clemson.edu/irrig/equip/ram.htm - http://www.clemson.edu/irrig/equip/ram.htm
http://www.motherearthnews.com/diy/hydraulic-ram-pump-zmaz79mjzraw.aspx - http://www.motherearthnews.com/diy/hydraulic-ram-pump-zmaz79mjzraw.aspx
Date Posted: 01-Mar-2014 at 17:00
otkako coek besplatno ke ja sprovede izvorskata voda doma il niva mu ostanuva uste istata da ja isfiltrira i omekne, pokraj hemiski so natrium vtorovo se prai i so magnetiziranje na vodata [ http://www.triplepundit.com/2009/09/omni-enviro-water-magentization-decreases-irrigation-use/#comments - 1 ][ http://www.build.mk/forum/forum_posts.asp?TID=1719&PID=167570#167570 - 2 ] a toa najlesno i najeftino bi bilo preku neodumski magneti namesto gotovi sklopki [ https://www.kjmagnetics.com/blog.asp?p=water-treatment - 3 ]
majtap so neodiumski super magneti nema http://amasci.com/neodemo.html - http://amasci.com/neodemo.html
a vo nedostatok od dostava moze da se iskopa od vishok hard disk [ http://youtube.com/#/watch?v=ttcLQgTLC8M - 1 ]
[tube]zwbYgsrNk-A[/tube]
Date Posted: 01-Mar-2014 at 19:55
preku ona videoto od linkot za nd-magnet od hardisk, naletav na ekstra info za vrakjanjevo vo zivot zaminati hardoi, ta sega malku izgleda smesno shto (vo sekoj sluchaj) gorat asolno toa recovery labosite [ http://www.build.mk/forum/forum_posts.asp?TID=646&PID=53925#53925 - 1 ] duri i da ne e otidena glavata
na videovo meshtreto koristi - Wiha Adjustable Torque Screwdrier [ http://www.stanleysupplyservices.com/search.aspx?f=1%3a1904%2c1%3a2364%2c1%3a2367%2c1%3a2371 - 1 ] eden padnat hard imam so vakov problem, iako mi potvrdija deka ne e zaminata plockata [ http://youtube.com/#/watch?v=PoVBHG4kajA - 1 ] a so ogled deka skopje ne uspeav da go opravam a labosite v belgrad i zagreb baraa od 500 do 1000 evra, jasno monopol, ta izgleda i ova bi go probal za da vratam vo zivot eden terabajt kitapi, ta duri potem dokolku ne mine ova bi osol kaj niv, no i vo toj sluchaj ako pak krenat cena poprvo sam bi nabavil jonizator za cista soba i eventualno chitach il zamensko kukjiste od hardot, bar sekoe evro ke mi se vrati
[tube]5CAn22TiVV0[/tube]
Date Posted: 11-May-2014 at 23:11
im se pogodilo vremeto :-)
[tube]c0_oKHARhXw[/tube]
Date Posted: 13-May-2014 at 13:40
pogore ima lapsus okolu hemisko tretiranje na vodata kade treba da stoi hlor no najverojatno sum presolil denta rucekot ta sum zacinil i muabetot potaka
navodno ne e opasna pojava seopshtoto tretiranje na vodata so hlor no lichno bi izbral drug metod na filtriranje ko predlozenite po linkoite pogore, no dobro e da se ima predvid kako moze choek da se posluzi so hlor dokolku e vo nebrano, sepak treba da ima predvid nestabilni reakcii na hemikalii (dokolku gi ima naokolu) no i kolku i kako bi go rastvoril hlorot
Does the TapWaterCompany add any chemicals to the water?
- Yes, chlorine, in the form of 12.5% sodium hypochlorite (liquid bleach) is added to most TCPUD water sources. This is added to maintain a safety barrier for the customer in the unlikely event some type of pathogenic organism contamination occurs. Although the chlorine is often noticeable by taste and smell, we maintain very low chlorine residuals (0.2 to 0.3 parts per million) to provide an adequate safety barrier while minimizing the effect on the taste and odor of the water. Occasionally, higher levels of chlorine are required during system maintenance, however these levels should return to normal within 2-48 hours, and do not pose a health threat.
http://suburbansurvivalblog.com/diy-how-to-make-chlorine-bleach-from-pool-shock - http://suburbansurvivalblog.com/diy-how-to-make-chlorine-bleach-from-pool-shock
http://www.water-research.net/watertreatment/chlorination.htm - http://www.water-research.net/watertreatment/chlorination.htm
povtorno, vnimavajte kako terate so hlorot bidejki e otrovna pojava, kade kade povekje primer od boraks [ http://www.build.mk/forum/forum_posts.asp?TID=1730&PID=172521#172521 - 1 ] iako i nego ne bi go preporacal
[tube]JeUfCVoe3As[/tube]
Date Posted: 13-May-2014 at 15:50
kitchen chemistry znae da bide korisna pojava, konkretno vo slucajov za kalapi, longeti, lepila nalik zatki i tapi
http://wikihow.com/Curdle-Milk - http://m.wikihow.com/Curdle-Milk
[tube]VFvik_THcNQu[/tube]
Date Posted: 06-Jun-2014 at 04:15
[ http://www.build.mk/forum/forum_posts.asp?TID=2078&PID=175779#175779 - 1 ][ http://www.woohome.com/diy-2/37-diy-hacks-and-ideas-to-improve-your-kitchen - 2 ] http://www.viralnova.com/garage-organization/ - http://www.viralnova.com/garage-organization/ [ https://www.youtube.com/watch?v=BMCAst7-ym0 - 1 ][ https://www.pinterest.com/scottmcg/garage-hacks/ - 2 ][ https://www.youtube.com/watch?v=N0rOspAOgx8 - 3 ]
http://www.lifehack.org/articles/lifestyle/100-life-hacks-that-make-life-easier.html - http://www.lifehack.org/articles/lifestyle/100-life-hacks-that-make-life-easier.html
[tube]UjdMAF4tPmc[/tube]
Date Posted: 07-Jun-2014 at 13:21
ako neshto e najpotrebno letovo toa e klima, iako najzdrava pojava e prirodno razladuvanje preku 1.makalo od luk i ocet ili 2.chaj od hibiskus, sepak ponekogash mi dojaduva sparinata i pomisluvam da zakacham erkondishn iako e bolest istiot, ajde ako e za uteha kaj nas nema tolku vlaga vo vozduhot pa i sparinata e popodnosliva
najverojatno dobra alternativa diy-aircondition dovolno primitiven za choek da go improvizira i na kraj na svet, dokolku se najde neshto kocki-freon i komp.kuler http://www.instructables.com/id/Home-Made-Air-Cooler-Conditioner/ - http://www.instructables.com/id/Home-Made-Air-Cooler-Conditioner
no ko shto veli meshtrevo na videovo, vo realnost vakviot erkondishn e povekje nalik high-tec ventilator koj nema sila da da ja razladi kukjata nego osvezi sobata, a negoviov prototip na pasivno ladenje so - Prirodna Promaja i vodena zavesa na prozor, iako ekstra, mislam za da bidne idealen treba da se kombinira so voden krov [ http://www.build.mk/forum/forum_posts.asp?TID=506&PID=106973#106973 - 1 ] od koj bi se slevale vodopadi po sekoj prozoro od sekoja soba, a seto toa da go vrti hidraulichna pumpa ko od post 3 pogore
[tube]6ScZiMiva9M[/tube]
Date Posted: 17-Jun-2014 at 13:01
eve zimska zakrpa vo staklenik po princip na kalorifer ili topla vozdusna zavesa, samo mesto grejach pred ventilatorot teraat sijalici, ko reshenie korisno i za planinski ili pustinski staklenici odnosno plastenici a koi se na udar na niski vecherni temperaturi [ http://www.build.mk/forum/forum_posts.asp?TID=468&PID=174654#174654 - 1 ]
[tube]azkRWHP5hbk[/tube]
sepak poidealno reshenie e vkopan plastenik, a vo ekstremni predeli i podzemen kade svetlina bi se dovela preku solar-tube kanali ko na velux [ http://www.build.mk/forum/forum_posts.asp?TID=903&PID=109409#109409 - 1 ][ http://www.youtube.com/watch?v=3VA5IzwQwvc - 2 ][ http://www.youtube.com/watch?v=Er2rDo4dnyk - 3 ] pod predpostavka deka za vlagata ima dehumidifier ili paropropusni kanali, vo sprotivno opcija e i veshtachko osvetluvanje no istata ne e samoodrzliva nit pak eftina i ednostavna za manipulacija
Date Posted: 06-Jul-2014 at 20:59
http://wonderfulengineering.com/50-life-hacks-that-will-make-your-life-easier/ - http://wonderfulengineering.com/50-life-hacks-that-will-make-your-life-easier/
http://wonderfulengineering.com/14-uses-of-vinegar-that-will-make-your-life-easier/ - http://wonderfulengineering.com/14-uses-of-vinegar-that-will-make-your-life-easier/
http://wonderfulengineering.com/100-clever-life-improving-ideas-that-you-can-use-in-everyday-life/ - http://wonderfulengineering.com/100-clever-life-improving-ideas-that-you-can-use-in-everyday-life/
Date Posted: 22-Jul-2014 at 21:13
http://survivallife.com/2013/01/31/80-uses-for-paracord-what-did-i-miss/# - http://survivallife.com/2013/01/31/80-uses-for-paracord-what-did-i-miss/#
[tube]7uXSHiIytZU[/tube]
do dusha kevlar rope e po saglam so ogled deka moze da izdrzi ekstra visoki temperaturi http://www.us-rope-cable.com - http://www.us-rope-cable.com
[tube]N0hkZZBruco[/tube]
Date Posted: 30-Jul-2014 at 19:33
[tube]1iJTjful66M[/tube]
Date Posted: 04-Aug-2014 at 11:10
http://gear-report.com/hammock-camping-basics-illustration/ - http://gear-report.com/hammock-camping-basics-illustration/
http://www.build.mk/forum/forum_posts.asp?TID=481&PID=47664#47664 - http://www.build.mk/forum/forum_posts.asp?TID=481&PID=47664#47664
[tube]U07rMsuZzJc&start=1724[/tube]
http://pineapple.myfunforum.org/Hammock_Style_Wilderness_Chair_about1364.html - http://pineapple.myfunforum.org/Hammock_Style_Wilderness_Chair_about1364.html
[tube]I2ujas-fwig[/tube]
Date Posted: 31-Oct-2014 at 19:32
[tube]WoaLGvJkoP8[/tube]
Date Posted: 18-Nov-2014 at 15:34
Survival Mode
in nature use only Guarana cans
[tube]ipMd5A7eUsc[/tube]
in nature take solar charger
[tube]oXK75SfUmBg[/tube]
mouse trap [ http://www.homecrux.com/2015/09/02/33974/raspitrap-photo-alerting-mouse-trap-with-raspberry-pi.html - 1 ]
[tube]VtUfjUpHVEw[/tube]
Date Posted: 31-May-2016 at 14:31
лесно на оние со хакерски табиет
[tube]PmYMSLhlEgg[/tube]
[tube]mWPYkQYdbcM[/tube]
Date Posted: 17-Jun-2016 at 08:55
или со индиска креативност
http://www.france24.com/en/20140216-down-earth-frugal-innovation-india-space-lowcost-hightech - http://www.france24.com/en/20140216-down-earth-frugal-innovation-india-space-lowcost-hightech
[tube]jJ-tTrZPvag[/tube]
Posted By: beTon
Date Posted: 12-Jul-2016 at 18:22
велат супер импровизација против комарци е загорена Жалфија, особено при вечерна скара, а лично свежа алое вера како стик ми е фаворит
оригинална то штипалката од вилушки
[tube]uhA5zJLhBvY[/tube]
Posted By: Zelenikovo
Date Posted: 17-Jul-2018 at 15:41
ајде за комарци има многу растенија кои можат да ги дефокусираат, а научно велат сулфурот од лукот пример ги брка
https://outdoors.stackexchange.com/questions/1560/eating-matches-to-repel-insects - https://outdoors.stackexchange.com/questions/1560/eating-matches-to-repel-insects
https://articles.mercola.com/sites/articles/archive/2014/08/23/mosquito-repellent.aspx - https://articles.mercola.com/sites/articles/archive/2014/08/23/mosquito-repellent.aspx
но што е со мувите? има еден мит кој е логичен но сеуште не е испитан доволно во секакви околности, кеса со вода и метални пари, а кои на сонце ги заслепуваат мувите односно им причи така прекршениот отсјај, иако претпоставувам доколку има неодолива арома по њух и заслепњни ќе влетуваат
https://www.hoax-slayer.net/do-water-filled-zip-lock-bags-with-added-pennies-keep-flies-away/ - https://www.hoax-slayer.net/do-water-filled-zip-lock-bags-with-added-pennies-keep-flies-away/
https://www.quora.com/People-are-hanging-a-bag-full-of-water-and-coins-and-are-claiming-that-it-keeps-mosquitoes-and-flies-away-If-this-is-true-then-how-does-it-work/answer/Patti-Charron - https://www.quora.com/People-are-hanging-a-bag-full-of-water-and-coins-and-are-claiming-that-it-keeps-mosquitoes-and-flies-away-If-this-is-true-then-how-does-it-work/answer/Patti-Charron
но не претпоставувајте, науката веќе има одговорено дека мувите https://medicalxpress.com/news/2016-08-motion-t4-cells-brain-complex.html - заради специфичните очи ко што може да се види од следниот линк и навистина имаат гајрет од распрсната светлина т.е. рефрактирачки ефект кој го имаат паричките во кеса со вода посекако ќе ги уплашат мувите, но која мува колку страв има тоа сеуште не е обајснето!
19.10.2009 - https://www.photonics.com/a40075/p6/v40/i403/Lasers_Twist_Fly_Memories - https://www.photonics.com/a40075/p6/v40/i403/Lasers_Twist_Fly_Memories
та гледајте искористите максимум рефрактирачки ефект можеби со то dc-fix фолиите ил слични [ http://www.infinityfoils.com/holographics_new.cfm - 1 ] ако немате парички а имате кредитни картички, ем потопете ги нормално во кеса со вода ... може да си поиграте и со аголот, пример во село пробав со парички во кеси за коцки мраз кои некако ги испикав и навистина експериментот ми имаше ефект, ко пијани дремеа мувите макар и јадење сум остаил на маса!
[tube]ujC9cUJXyFM[/tube]
Date Posted: 17-Jul-2018 at 16:31
да не излезе неразбирлив научниот линк горе, бидејќи во него се апострофира дека оптогенетички си експериментирале оксфордци но нема подетални информации, та еве поубо објаснување дека мувите се држат до претедерминирани патерни, а логично непозната рефракција би ги уплашила, а ако кесите не ви вршат работа ко статични, пробајте направете http://www.build.mk/forum/forum_posts.asp?TID=156&PID=49035#49035 - кинетичка скулптура со нив како би имале и поголем ефект од светлосни рефракции
https://mediaspace.gatech.edu/media/How+a+Fly+Sees+the+WorldA+Optogenetics%2C+Systems+ID%2C+and+Optophysiology+of+Visual+Flight+Control+in+Drosophila+-+Mark+Frye/1_qjvraq3d - https://mediaspace.gatech.edu/media/How+a+Fly+Sees+the+WorldA+Optogenetics%2C+Systems+ID%2C+and+Optophysiology+of+Visual+Flight+Control+in+Drosophila+-+Mark+Frye/1_qjvraq3d
сепак како и кај бравите доколку имате неодоливи ароми во свое опкружување навистина прашање е колку само со една техника ќе имате безбеден ако не сигурен Мир од муви, а за целосно осигурување сигурно треба и мултилевел подршка пр. фина мрежа каде се мора [ https://www.youtube.com/watch?v=ptBS5V9UKDQ - 1 ] или природни спрејови каде се може [ https://www.smartpakequine.com/pt/outsmart-fly-spray-14237#reviewsTab - 2 ]
Date Posted: 18-Jul-2018 at 00:01
да спомнам дека овие постови може се поарни за во http://www.build.mk/forum/forum_posts.asp?TID=1029 - нишката за ДДД , но таму бидејќи целта е истребување, та како техника за импровизирано бркање на муви мислам поприкладно е да одат абериве тука
би напоменал дека во ваков контекст слично ловам а потем и ослободувам бубашваби, односно со едноставна тенџерче стапица сами се заловуваат внатре и неможат да излезат, а посетне ги пуштам подалеку од моето опкружување, што е изводливо нели доколку нe се работи за наезда! во кој пак случај единствено чаре е емф направија за одвраќање [ http://kenford.com.sg/heavy-duty-emf-pest-repeller.html - 1 ] но бидејќи нишкава е за импровизации логично еве и соодветен абер, иако мора да напоменам дека вакво решавање на еден проблем може да предизвика друг во однос вашето здравје та поарно не експериментирајте, чим навистина има негативен ефект на животни http://www.dtic.mil/dtic/tr/fulltext/u2/a410642.pdf - стр.251 зошто мислите нема да има и на вас, заради што во крајна нужда ете бар логично би било да е вклучен ваков ултрасоничен одвраќач единствено кога не сте дома!
https://www.circuitlib.com/index.php/schematics/product/50-ultrasonic-pest-repellers/category_pathway-33 - https://www.circuitlib.com/index.php/schematics/product/50-ultrasonic-pest-repellers/category_pathway-33
http://www.instructables.com/id/DIY-Rechargeable-Electronic-Mosquito-Repeller/ - http://www.instructables.com/id/DIY-Rechargeable-Electronic-Mosquito-Repeller/
[tube]izaJjjLhs2w[/tube]
Date Posted: 18-Jul-2018 at 12:12
ултра инфра нели илк ќе се исечете или ќе се отупите, горе имет лапсус во чекори, треба инфразвук да стои бидејќи се во прашање ниски фрекфенции оние кои не би требало да ги има по медиуми но ги има од музика преку филмои оа се до емисии а нормално и социјални мрежи, а вие чудете се дали хаксли зборел само за агитпроп апови!
нејсе, кога веќе вака думам, убо е да знаете што може утре да импровизирате и чсо утразвук освен ифразвек, односно може сте чуле дека докторите оперираат без да отворат ткиво со вакви скалпери пр. синуси чистејќи ја мукозата вака иако прашање е колку прецизноста е 100% дури се праело тоа во живо со постојните томографи, претпоставувам вака утре нанороботи ќе мора да се неутрализираат медицински, но бидејќи форумов е технички ќе се задржам на сродните области ... интересно е да се намене дека утре може ултразвучно да функионира репликатор за храна [ http://www.cymaticsource.com/pdf/ks_shaping%20up_06.pdf - 1 ] или пакн фасадна орнаментика, можеби билдање мавзолеи [ https://www.youtube.com/watch?v=QrknhRCQdC4 - 2 ]
за сега технички сонарни е најупотребувана ваквата технологија но без осет корпоратистички иако за среќа имаме свест граѓански дека е така [ www.build.mk/forum/forum_posts.asp?TID=559&PID=223046#223046 - 3 ] а за масовен пазар е достапна како опрема за чистење која може да се пренамени во направија за неотупиво сецкање, иако вакви diy експерименти не се за секого та дури зорт за упатени гаражни мајстори доколку не ги обденил ден со лесно ... ова му се случило и на Тесла со неговата земјотрес алатка [ https://www.physicsforums.com/threads/teslas-resonation-machine.489763/ - 4 ] уште во 30-тите години од минатиот век [ https://teslaresearch.jimdo.com/oscilators/mechanical-oscilator/ - 5 ] по што лабосот фби му го пали алатките конфискува и ги дава на пентагон со нив да си игра, каде како си играле понтигонци тоа е друга работа!
https://en.wikipedia.org/wiki/Ultrasonic_transducer#Use_in_industry - https://en.wikipedia.org/wiki/Ultrasonic_transducer#Use_in_industry
https://makezine.com/2018/03/05/experimenting-with-turning-an-ultrasonic-cleaner-into-an-ultrasonic-knife/ - https://makezine.com/2018/03/05/experimenting-with-turning-an-ultrasonic-cleaner-into-an-ultrasonic-knife/
[tube]pFeek0a8s7Q[/tube]
Date Posted: 20-Jul-2018 at 13:00
кога сме кај ултразвуков може да се каже дека постои начин како да се добие полесно сечење или бушење камен и со арпаџик направии [ http://www.build.mk/forum/forum_posts.asp?TID=1765&PID=227227#227227 - 1 ] а кои во современа форма има обиди да се стандардизираат и ко рачни бушилици [ https://en.wikipedia.org/wiki/Ultrasonic/sonic_driller/corer#History - 2 ] а за сега ги има само како масивни или статични [ http://www.rajtools.com/udm.htm - 3 ] иако ги има како рачни за заварување [ https://www.belsonic-machines.com/en/equipment/hand-held-ultrasonic-equipment - 4 ] и сечење [ http://www.build.mk/forum/forum_posts.asp?TID=3031&PID=227225#227225 - 5 ]
за сега како импровизација звучна т.е. акустична вилушка може да се искористи како био-техничко помагало заедно со стетоскоп во медицината за арпаџик откривање скршеници [ https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2681212/ - 1 ]
а понатакa можеби ќе се направат поедноставни рачни бушилици, кои за да бидат на овој принцип, претпоставувам резонацата може да се побуди со магнет или магнети кои ќе ротираат околу акустичната вилушка а што доколку бидне ефективно ќе значи помалку работа за производителите на бушилици иако полесно работа за гредежници ... незнам дали експерименти во гаража можат да доведат до некаков резултат, но и вдената акустична вилушка со магнети ротирани околу резонаторот дури и рачно би требало да предизвикаат некаква доволна осцилација за да во помек материјал има некаков ефект дури и со тапа основа а не пак ако истата е под агли со кои се прават бургиите, но мене ова не ме импонира за експериментирање знаејќи дека експерименти знаат да излезат од контрола, а во некотролирани околности ем со малку абер за одредени ризици јасно дека може да има несакни ефекти, слично кои и она њуејџ праксата каде со звучни вилушки оправаат некому психа или стрес, а реално нема доволно научен абер за и да кажеме дека арпаџик може вака да се оправи некаков здравствен склет, иако квантната медицина е се повече тренд каде ова се прави машински со аплицирање на одредено место на телото фреквенции, кај нас ординацијата на др.Сарчевски ...
инаку еве за што се можете да импровизирате со рачна штрафилица или мала бушилица ...
[tube]6och7-0iI00[/tube]
Date Posted: 25-Feb-2019 at 12:45
еве иноватори на кои не им здосадило да ги бркаат фреквенциите, ќе го рушат изгледа и факелот на либерти инфразвучно, логиката е дека можат [ http://forum.idividi.com.mk/forum_posts.asp?TID=27882&PN=2&title=nwo - 1 ] сепак иновацијата им е за пожари [ http://archive.is/PYnMN#selection-4687.493-4687.722 - 2 ] а можеби резонирање на иста фреквенција го решава проблемот и за горски пожари единствено треба долг ултразвучен извор [ https://ieeexplore.ieee.org/document/1025715/ - 1 ]
https://spinoff.com/forcesv - https://spinoff.com/forcesv
https://www.allaboutcircuits.com/news/ge-unimpossible-missions-series-part-one/ - https://www.allaboutcircuits.com/news/ge-unimpossible-missions-series-part-one/
Date Posted: 21-Mar-2020 at 19:31
за индивидуални импровизации чинам сме кадарни, но дали и за институционални ќе не биде, мислам ако Тесла своевремено можел [ http://www.build.mk/forum/forum_posts.asp?TID=3134&KW=теслиниот+вибратор&PID=235673#235673 - 1 ][ http://archive.is/BKB0j#selection-1579.0-1689.4 - 1 ][ https://books.google.mk/books?id=WerR9lPgub0C&pg=PA522&lpg=PA522&dq=medicine+germs+tesla&source=bl&ots=3QucTRnZ1J&sig=ACfU3U0T4XPCKMrptsFDAFE4dipp20ktow&hl=en&sa=X&ved=2ahUKEwig9O6OmKzoAhVtlosKHT3BA_QQ6AEwDXoECBYQAQ#v=onepage&q=medicine%20germs%20tesla&f=true - 1 ] зошто и други денес да неможат, во случајов некој од ЕТФ во соработка со микробиолошкиот Лабос во МАНУ т.е. таму да експериментираат Сонографски [ https://neurosciencenews.com/sonogenetics-brain-control-14689/ - 1 ] за преку инфразвучни резонатори [ http://forum.idividi.com.mk/forum_posts.asp?TID=31572&KW=%F7%F3%EA%F8&PID=3152912#3152912 - 1 ] ништејќи на клеточно ниво вируси бактерии склет патогени воопшто извадат некаков анти’џрм’бумбокс ко што постои и за тинејџери [ https://www.dailymail.co.uk/news/article-2343706/Couple-installed-high-pitch-mosquito-alarm-ward-racist-teen-vandals-investigation-noise-nuisance.html - 2 ][ http://www.build.mk/forum/forum_posts.asp?TID=1023&PID=195900#195900 - 2 ][ https://www.independent.co.uk/news/sonic-youth-the-high-pitched-sound-alarm-for-under-25s-8665652.html - 2 ] бар за по ходници на јавни институции, Но тоа не може да е студентајла ко во случајот со ув-ц [ http://www.build.mk/forum/forum_posts.asp?TID=3325&KW=студентите&PID=237531#237531 - 3 ] туку треба наоро да се фатат магистри асистенти доценти а деканат топтан да ги контролира! само нека не се правдаат дека за такво нешто им треба посебен лабос бидејќи и на постојните инкуватори во тој на МАНУ можат комотно да зрачат од страна по патогените!
