Осветлување
 Post Reply Post Reply Page  <1 1011121314 19>
  Quote beTon Quote  Post ReplyReply #221 Posted: 19-Jan-2015 at 00:19
http://lasersandlights.com/festival-specials-c-33.html
rl]]
http://www.dhgate.com/wholesale/night-lights
можеби во контекст празничен екст. декор [1] добро би дошле и топшоп закрпи [2][3][4]
Edited by beTon - 10-Oct-2016 at 07:22
  Quote beTon Quote  Post ReplyReply #222 Posted: 19-Jan-2015 at 18:00
CONSTELLATION LAMPS AND PROJECTORS
There’s something enchanting about the night sky. In it, we see a constellation-style history of human mythology, and the possibilities of our future looking down at us from above. This iconography of stars is something our culture celebrates in many different ways, but these new constellation lamps and projectors are a brilliant homage to the one worldview we all share. So when you’re not gazing through your Impala’s available sunroof or letting the sky guide your path with the available Chevrolet MyLink Radio with Navigation*, check out some other ingenious ways to bring the beauty of the heavens into your home.
STARRY LIGHT LAMPS - http://starrylightlamps.com/lamps/
A fresh, modern living space requires abundant, artful light. Starry Light Lamps by Hungarian design duo Anagraphic deliver both in an inventive and authentic way. These handmade half-globe pendant lamps feature carved constellations. The bulb inside illuminates the room below and the ceiling above through accurate star map perforations. With the flick of a switch, the Northern Hemisphere’s starry skies are recreated on your walls and ceiling.
Constellation Lamp - http://www.japantrendshop.com/kaguya-constellation-aroma-lamp-p-652.html
If the museum-quality Starry Light Lamps eclipse your budget, the Constellation Lamp by Urban Outfitters is a bit more down-to-Earth. This small-stand lamp fits on a desk, coffee table or night table to light part of your room and project star shapes on your nearby wall and furnishings. It’s exciting, accessible and will satisfy the stargazer in you.
Star Theater Pro Home Planetarium - http://www.thinkgeek.com/product/c057/?cpg=cj&ref=&CJURL=&CJID=2617611
The serious star buff might prefer something with scientific accuracy. This impressive little device uses interchangeable image discs to project bright constellations onto your ceiling just as they appear in the night sky. It runs on either batteries or an AC adapter. And it features a built-in nap timer, so it will shut itself off if you fall asleep while pondering the starry skies.
DIY Romantic Star Projector - http://www.infmetry.com/diy-romantic-star-projector
If accuracy isn’t as important to you as mood, consider this do-it-yourself system. You assemble it and install where you like. An ethereal night sky will appear on your ceiling and walls. This star projector is no educational tool, but it can turn almost any room into a dreamy environment.
Fiber Optic Night Sky Mural
http://www.nightskymurals.com/star-ceiling-fiber-optics-vs-a-painted-night-sky-mural/
If you prefer something a bit more permanent, there’s always the installation option. There are various companies that provide starry sky murals for a special ceiling in your home, using either reflective paint or inset fiber optics. The fiber optic systems can be designed to reflect the night sky accurately and shine light down onto the room from above. While this might be the most costly option, it can also be the most accurate and the most visually impressive.
  Quote beTon Quote  Post ReplyReply #223 Posted: 19-Jan-2015 at 20:20
зошто бе толку едноставно !:?
  Quote Max Quote  Post ReplyReply #224 Posted: 20-Jan-2015 at 01:31
а зошто не и пооригинално !:?
http://www.17apart.com/2012/10/were-seeing-stars-our-constellation.html
  Quote beTon Quote  Post ReplyReply #225 Posted: 20-Jan-2015 at 12:31
и за Лантерна и за Столна ќе го биде ѕвезениов муабет
http://www.stampcreative.com/shop/product.asp?catID=28&productID=267
  Quote beTon Quote  Post ReplyReply #226 Posted: 22-Jan-2015 at 11:44
едноставно корисен патерн за илуминирани соѕвездија по ѕид
http://www.britishwomenartists.com/art-show.php?art=912#sthash.iWnSSeaE.dpbs
  Quote beTon Quote  Post ReplyReply #227 Posted: 22-Jan-2015 at 15:03
  Quote beTon Quote  Post ReplyReply #228 Posted: 22-Jan-2015 at 20:15
  Quote Max Quote  Post ReplyReply #229 Posted: 23-Jan-2015 at 11:44
ко да е измислено за жонглери
http://www.paulfriedlander.com/
кога панорамски би проектирале вакви светлосни скулптури впечатокот ќе биде и далеку покинетички пр. во контекст на панорамски видео ѕид [1]
Edited by Max - 01-Feb-2015 at 20:20
  Quote beTon Quote  Post ReplyReply #230 Posted: 27-Jan-2015 at 08:39
во контекст пост #5 од нишкава, иако таму олед-от се посочува како недоносен во однос лец-от сепак тв ѕидовите на панасоник ова го одминуваат со својата појава на заоблени 4к тв ѕидови
http://www.hdtvtest.co.uk/news/panasonic-4k-oled-201501073969.htm
  Quote beTon Quote  Post ReplyReply #231 Posted: 27-Jan-2015 at 10:16
веројатно спој на светло и тв е следната фаза на денешново осветлување, каде секоја стаклена површина би можела да се обложи со транспарентна олед фолија, што како појава иако подолго е во најава сепак конечно годинава ќе излезе во малопродажба иако за сега минималистички [1][2][3] но веќе има џамбо олед панели за освтлување кои се воедно и транспаретни иако не се нешто најдостапни
To shed some light on OLEDs, here’s a primer on an idea that some experts believe will revolutionize how we see living spaces.
What is OLED lighting?
Organic light-emitting diodes, or OLEDs are similar to LEDs in that they’re comprised of semiconductor material sandwiched between two electrodes. But while LEDs use a blue semiconductor diode combined with yellow phosphor to produce light, OLEDs combine thin layers of red, green, and blue film to emit a softer white light. OLEDs can also be laid onto a variety of flexible and rigid surfaces, such as glass, metal or plastic, to create a light source that radiates along a broader area rather than from a single point.
Is OLED lighting better than LED?
It depends. OLED lighting still has a lot of ground to make up when compared to popular alternatives such as LED, which offers twice the energy efficiency and at a fraction of the cost. Fashioned as light bulbs, LEDs emit a more concentrated light that travels across longer distances. Spaces where LEDs perform well include high ceilings, a tall stairwell or wherever a spotlight is needed.
OLEDs are known for producing the kind of high quality illumination that more closely resembles natural sunlight, though many high-end LEDs have been able to achieve this. OLED also tends to be superior at bringing out the true colors of surroundings, such as furniture and nearby objects. Its rating on the color rendering index, a measure of how well a light source performs in this regard, is consistently above 90. The maximum score is 100 (sunlight).
  Quote beTon Quote  Post ReplyReply #232 Posted: 27-Jan-2015 at 12:41
  Quote beTon Quote  Post ReplyReply #233 Posted: 27-Jan-2015 at 18:28
ова олед инфово во добар дел е за во нишката Оптоелектроника но заради редослед нека одат постовиве тука, плус пополека се намалува границата помеѓу светлото и телевизијата, та наскоро целосно опкружени со нив ќе летаме или возиме
http://www.boredpanda.com/windowless-airplane-oled-touchscreen-walls-cpi/
http://www.theguardian.com/business/2014/oct/26/innovations-windowless-plane
  Quote beTon Quote  Post ReplyReply #234 Posted: 31-Jan-2015 at 22:24
  Quote beTon Quote  Post ReplyReply #235 Posted: 01-Feb-2015 at 06:09
  Quote beTon Quote  Post ReplyReply #236 Posted: 01-Feb-2015 at 16:16
вакво нешто е идеално и за в двор доколку е достапно [1][2][3]
  Quote Max Quote  Post ReplyReply #237 Posted: 01-Feb-2015 at 20:50
доволно избегано и за на јавни места ко симболика за опуштање
додека се смогне сили и за нешто пооднесено а урбано развиорено
  Quote phenomenon Quote  Post ReplyReply #238 Posted: 01-Feb-2015 at 21:17
Зевсафон:
  Quote beTon Quote  Post ReplyReply #239 Posted: 02-Feb-2015 at 14:14
кога ќе улета овој фено со некоја зелена иди врати нишкава у нормала
  Quote phenomenon Quote  Post ReplyReply #240 Posted: 02-Feb-2015 at 15:48
Што бе зелена? Имаш 2 во 1, и светло и звук во една направа.
This page was generated in 0.432 seconds.
