Света Злата Мегленска во Загреб
AdmiraloT View Drop Down
  Quote AdmiraloT Quote  Post ReplyReply #1 Topic: Света Злата Мегленска во Загреб
    Posted: 16-Jul-2008 at 18:29
Croatian architects bif studio have won a competition to design a new Macedonian Orthodox church in Zagreb.
The concrete building will include a pastoral centre and an apartment for the priest.
Construction is due to begin in 2009.
The following information is from the architects:
The preliminary project won the first prize in the competition by invitation from the Macedonian Orthodox Church in Croatia in October 2007. The location of the Church is in the center of the city, beside one of the main city avenues.
The project will run from May 2008 and is planned to be finished by December 2008. The construction would start in 2009.
The building of the Pastoral center and the Macedonian Church of the Orthodox parish “Sv. Zlata Meglenska” merges with the present ambience of the urban matrix of Stara Knežija beside the Ljubljanska Avenue in Zagreb.
Situated on the suggested location, the building is trying to blend with the environment by assembling and expanding all its parts, since this is its sole place of existence. It is to be hoped that, if the place and the building become one, physical and functional demands will be surpassed and the city area will acquire new values.
The plan is that the entrance to the Church and Pastoral center should lead from the pedestrian zone alongside the Ljubljanska Avenue through the tree-lined road on the north side.
The building does not have an open square that would lead toward the entrance, but the Church and the Pastoral center will have an open entrance-court that develops over the perforated wall as a protected courtyard. Thus, even the gathering of people on the open area in front of the Church may make the space more intimate, moving it away from the traffic jam.
The plan is to make the entrance below the steeple that covers it like giant eaves; the entrance will expand onto the courtyard domed over by a mulberry-tree, leading to the Pastoral center. The covered area leads you further to the front area of the Church, an area from where a vertical communication leads to the Church choir and service connection for the steeple.
The front area is lit by a glazed wall on the north side and by a smaller garden alongside the roofed porch. The plan is to build the Church nave as a parallelepiped volume with a barrel-shaped arch extending along the entire nave, distancing itself from the walls and ending in the iconostasis wall.
The entire area is closed, lit by a diffused light coming from the above, from the narrow hollows on the northern wall of the nave, and by a roof light coming from the south side. The light coming from these directions is dispersed over the barrel-like arch and reveals the intimacy and darkness of the nave with its entire spectrum. Opposite the iconostasis, the entrance wall under the choir is covered with wooden facing.
According to this proposition for the design, the walls and the ceiling of the main nave are left as empty book pages, waiting to be filled with contents. The elevated priest’s podium with the altar is situated in front of the iconostasis, and the plan is to light up the entire nave with big chandeliers.
The Pastoral center is conceived as a lean-to structure against the main nave, accessible by walking across the courtyard. The ground-floor comprises of the reception room and priest’s office that are connected to the altar area. A vertical communication leading toward the upper floor is located next to the entrance area of the Pastoral center. The plan is to arrange the entire upper floor as an apartment for the priest and his family, while the basement area comprises of the Church service rooms.
Although this is planned to be a basement area, it is lit and ventilated through the split-leveled courtyard and garden, thus providing it with intimacy and not disrupting the monumentality of the volume of the main Church nave. In this way, this intimate and multi-purpose area offers the possibility of congregational gathering and socializing, and it can be turned into a separate guest suite. Through the design of the building we tried to achieve a simple, yet symbolic composition in which the traditional influences can be clearly seen in the main disposition, while the intimate areas remain subtly concealed, remaining primarily dedicated to liturgy.
STRUCTURE
The plan is to build the Church and the Pastoral center with classic construction, with a basic structure of reinforced concrete which will surmount the rather small construction requirements. The nave of the Church ranging up to 9 meters is conquered by a straight ceiling panel and the barrel-like interior structure is tamed by a light mounting panel surface suspended on the structure. It is planned that the main part of the steeple be a monolithic structure stabilized in the basement area.
MATERIALS
It is planned that the main bodies of the Church and Pastoral center be made of cast-in-situ concrete, composed of white cement and chosen aggregate. With careful blending of materials of high quality, we plan to include the influence of the human labor which would always remain evident on the facade of the building. The main walls of the nave will be multi-layered and built in segments at sufficient time intervals, so as to sense the influence of time and human labor as a constituent part of the Church facade. The structure and the coating are executed side by side to the prepared cast with the incorporated thermal protection. The outer facade of the building is not treated, but just impregnated. The same method is used for the construction of the steeple and the outer wall of the Pastoral center.
The outer wall of the Church courtyard will be built using prefabricated perforated elements, also with no subsequent treatment. By selecting the material and properly using it, with a high degree of craftwork, we intend to present physical labor as a constituent part of the Church construction without disguise.
The basement area is connected to the intimate garden by a large glazed wall. According to plan, the floor of the nave is to be constructed in the form of a ceramic or stone mosaic and the walls will have a concrete surface with smooth edges.
Edited by Cloverstack - 02-Nov-2008 at 20:55
  Quote lslcrew Quote  Post ReplyReply #2 Posted: 16-Jul-2008 at 18:33
Ја почитувам модернистички градби и едноставни форми така да од мене црквава има оценка 4 (1-5). Не гледам проблем да има и вакви модернистички цркви. Кај нас имаше предлог исто така за модернистичка црква во аеродром, за кое го имам истото мислење.
  Quote zabegan Quote  Post ReplyReply #3 Posted: 16-Jul-2008 at 22:03
од внатре ми делува некако католички, нели православна пишува дека е, а однадвор е ок, само никако да ги најдам одликите на православна црква
мислам немам ишто против модернистички цркви, но воопшто ова не ми  личи на црква,
значи поддржувам и модернистички цркви, изградени од било каков материјал, но само ако ги имаат одликите на традиционална православна црква (форма, позиција и внатрешност)
пр. Соборниот храм е модерна црква, но со одлики на православна црква е
во секој случај мило ми е што во Хрватска се гради наша црква Smile
  Quote lslcrew Quote  Post ReplyReply #4 Posted: 16-Jul-2008 at 22:10
Црквава не делува ниту католички. Види ги катедралите низ Европа. Овде може да се каже дека делува малце протестанстски. Ама ипак мислам дека црковните канони може да се запазат и во ваков модернистички објект. А тоа што има клупи не значи дека е католички.
  Quote zabegan Quote  Post ReplyReply #5 Posted: 17-Jul-2008 at 00:36
мислев протестантски де, не католички, нешто сум се збунил, а за другото си останувам на истото мислење
GreatMakedon View Drop Down
  Quote GreatMakedon Quote  Post ReplyReply #6 Posted: 17-Jul-2008 at 12:34
Crazy ova ne e crkva, nekolku kocki beton spoeni zaedno... Wallbash
dejan View Drop Down
  Quote dejan Quote  Post ReplyReply #7 Posted: 17-Jul-2008 at 15:43
Не е нешто интересно. Барем некаков стил да му дадоа...иначе кога е до цркви не е важно изгледот ама сепак во ова време добро е малку да се дотера
  Quote lslcrew Quote  Post ReplyReply #8 Posted: 02-Dec-2009 at 02:48
Македонците ќе градат црква во Загреб
Македонската православна црковна општина „Св. Злата Мегленска“ идната година ќе почне да ја гради својата прва црква и тоа на раскрсницата меѓу улицата „Омишка“ и Загрепска авенија. Градот Загреб за 1,4 милиони куни (околу 190.000 евра) ќе им продаде околу 800 квадратни метри земјиште. „Тоа е наш прв верски објект во Хрватска. Во Загреб живеат 667 Македонци, а во Загрепската жупанија вкупно не' има 1.500. Но, во оваа црква би гравитирале и Македонците од другите градови, како Карловац и Сисак“, вели претставникот Кирко Велински, претставник на Македонската православна црква.
Досега Македонците за верскa служба одеа во капелата на свети Рок во жупата на свети Блаж, што на користење ја добија од Загрепската надбискупија уште за време на бискупот Фрањо Кухариќ.
„Таму ја извршувавме службата и веднаш си одевме. Сега откако ќе добиеме свој простор, ќе можеме уште малку да останеме и да се дружиме. Исто така, нема да мораме да најмуваме простории секогаш кога нешто ќе организираме. Во иднина се' ќе се одвива во црквата“, среќен е Велински.
Но, Македонската православна црква нема, како што е обичај кај сакралните објекти, да биде величенствена градба, туку скромна и невпечатлива. Повеќе ќе личи на голема куќа отколку на црква. Со оглед на тоа дека дозволена изградба на парцелата е 50 отсто, црквата нема да биде површински поголема од 400 квадратни метри.
Колку ќе чини изградбата и како ќе се финансира се' уште не знае ниту Кирко Велински. „Досега не можевме да преговараме, бидејќи го немавме земјиштето што толку долго го посакувавме. Сега имаме решение на конкретни работи, па ќе можеме да бараме и пари. Наредните денови ќе побараме процена на трошоците за изградба на црквата“, вели Велински. (Вечерњи лист)
http://utrinski.com.mk/?ItemID=C41A72F5F44BD048B4F76A3C6675C816
Zoc View Drop Down
  Quote Zoc Quote  Post ReplyReply #9 Posted: 15-Dec-2009 at 19:59
Како направена од кутии од цигари и од сируп ќе биде црквава...Воопшто не ми се допаѓа . Сметам дека е несоодветен дизајнот на овој објект за својата намена и речиси да нема никакви одлики кои ги има една вообичаена православна црква..
gorco View Drop Down
Google Maps: Regional Expert
  Quote gorco Quote  Post ReplyReply #10 Posted: 15-Dec-2009 at 20:09
Јас не разбирам каков иди*тски народ сме. Покрај толку богати култура и архитектура - видете ги црквите кај нас, види како се претставуваме надвор - ЕПА чорба Македонче, после не не бувало ((
  Quote гитардемон Quote  Post ReplyReply #11 Posted: 15-Dec-2009 at 20:19
Па добро, тој византиски стил го има и во Грција (повеќе отколку кај нас), а и во Бугарија, не сум сигурен дали и во Србија, па сепак нивните цркви во Австралија и Америките се многу слични на оваа што ќе ја градат нашите во Хрватска. Сепак да не заборавиме колку Хрватите не љубат православни цркви, а уште помалку на сред Загреб (си имаат свои причини, нели). Самото тоа што даваат да се гради православна црква таму е значајен показател на пријателство. Само сепак се надевам дека нема да страда, т.е. загребчани ќе знаат дека е македонска, а не на некој друг сосед.
А за сите што викате дека вака не изгледала православна црква, тоа е бидејќи сте навикнати на овие нашите. Како изгледаат православните цркви во Етиопија или Ерменија? Сигурно не како нашиве византиски.
http://images.google.com/images?sourceid=chrome&q=ethiopian%20orthodox%20church&um=1&ie=UTF-8&sa=N&hl=en&tab=wi
http://images.google.com/images?sourceid=chrome&q=greek%20orthodox%20church%20australia&um=1&ie=UTF-8&sa=N&hl=en&tab=wi
Edited by гитардемон - 15-Dec-2009 at 20:20
  Quote alexgizh Quote  Post ReplyReply #12 Posted: 15-Dec-2009 at 20:42
...ќе знаат дека е македонска, а не на некој друг сосед.
До кога ќе ги сметаме Хрватите за соседи? хаха
  Quote гитардемон Quote  Post ReplyReply #13 Posted: 15-Dec-2009 at 20:46
Сосед е некој од соседството Не мора да е веднаш до тебе. И Турција е еден од соседите, иако не прв сосед.
Шпер View Drop Down
  Quote Шпер Quote  Post ReplyReply #14 Posted: 15-Dec-2009 at 20:49
Православна црква без купола не е црква!
  Quote lslcrew Quote  Post ReplyReply #15 Posted: 15-Dec-2009 at 21:55
Купола не единствено какнонско правило за црква да биде црква. Ако се исполнат каконските правила ондак е црква, па како сакате нека изгледа и без разлика дали го имаме навикнато стилот или не.
И гитар бадијала ќе нја насочиш дискусијата во погрешен правец за православна црква сред Загреб. Убеден сум дека тоа не било никаков пресуден момент за стилот на црквава, а ниту пак гледам потреба од толкава хистерија меѓу Загребчани и ствар од православни цркви, небаре тие им се криви.
Dragan View Drop Down
  Quote Dragan Quote  Post ReplyReply #16 Posted: 15-Dec-2009 at 23:04
Кој свештеници ќе служат во таа црква?. Дали други православни народи(Србите, Руси) можат да идат во таа црква на молитва? Дали после ова во Македонија уште во некое село (Струмичко) ќе се гради Хрватска католичка црква. Убаво е ако градењето на цркви придонесува дозближување на луѓето од различни вери.
  Quote Andrej_LJ Quote  Post ReplyReply #17 Posted: 15-Dec-2009 at 23:27
Драган, во црквата ќе биде овозможен влез само на граѓани на ФИРОМ Ohno по детално извршена конторла на граничниот пункт кој би се наоѓал на 10 метри од главниот влез на објектот. Crazy Се разбира дека секој може да влезе, дури и лица што не се од православна вероисповед.Шегата на страна, мене црквава за како кај нас ми делува малку ладна, но незнам колку наш тип црква би била складна за типот на архитектура кој преовладува во Загреб. Сепак е доста невкусно да набутуваш објекти кои многу ќе отскокнуваат или ќе се диференцираат од околината. Се разбира и локацијата на самиот објект во рамките на градот е важна. Инаку самата црква ме потсетува многу на една во Прага (Kostel Nejsvětějšího srdce Páně v Praze), дело на великиот словенски архитект Јоже Плечник. И таа ги разбива сите стандарди за типична црква и мене не ми се допадна (ми изгледаше на железничка станица), но бидејќи во групата со која бев во Прага имаше и млади архитекти, тие ми објаснија всушност дека токму таму се крие посебноста и убавината на ваков објект. Доколку би седеле на едно место и не би развивале нови концепции, нема да има развој. Тие беа зачудени дека новите цркви во Македонија не содржат архитектурни елементи од денешницата, туку цврсто се држат до конзервативните правила. Сега тоа е дискутабилно дали е правилно или не, но во секој случај сакам една ваква црква во Скопје, да ни ја промени малку претставата за византискиот тип на црква како единствена правилна форма за православен верски објект.
Kostel Nejsvětějšího srdce Páně:
  Quote Max Quote  Post ReplyReply #18 Posted: 15-Dec-2009 at 23:38
ова е целосно отстапување и од Православниот Црковен архитектонски израз но и традицијата, значи и канонски и естетски!
http://www.build.com.mk/forum/forum_posts.asp?TID=625&PID=37313#37313
како и да вртиме современиот минимализам сам по себе наголемо ја нарушува православната симболика, но и топлината со која зрачат изворните Православни Храмови во смисла далеку поладно зрачат чистите линии кои се практика кај другите Христијански деноминации...
сепак доколку надлежниот Епископ даде за вакво нешто Благослов тогаш и ова ќе биде дозволено, исто како што Дедо Петар притеснет од можностите преадаптира Протестантска Црква во Сиднеј која сега е Православната Црква Воскресение Христово во Рокдеил http://upload.wikimedia.org/wikipedia/commons/1/18/Rockdale_Macedonian_Orthodox_Church.JPG
  Quote Dragan Quote  Post ReplyReply #19 Posted: 15-Dec-2009 at 23:55
@ Andreja Секоја православна црква без разлика од која држава е треба да прима верници што припаѓаат и на други православни народи, така е тоа кај католичките цркви. Во Скопје католичката црква е само Хрватска? и во неа може да одат само Хрват?кој зивеат во Македонија, колку знам за божиќ таму се собираат сите католици што живеат во Македонија. Сега за изгледот основно обележје на православна црква е влезот да биде од запад олтарот на исток спротивно од католичкитие, висината не е многу голема како католичките катедрали. Според она што на сликата го видов преставува една нормална архиктетура на православна црква
  Quote Max Quote  Post ReplyReply #20 Posted: 16-Dec-2009 at 00:43
Драган да нема забуна и кај Католиците Олтарот е на Исток!
во основа иста ни е традицијата само што веќе во времето на Јустинијан I православните го напуштаат базиликалниот тип на Црковна градба и предност даваат на Сферата како Симболика за Царството Небесно, во истовреме се градат и неколку куполи во рим и фиренца, но сепак оваа архитектонска интерпретација се задржува и развива во византија, и пред се во основа како впишан крст во квадрат како поспецифичен византиски стил, но напоредно и базиликалниот израз е постојано присутен... диспропорцијалните разлики кај Базиликалните Христијански Храмови почнуваат со појавувањето на готика, и потоа трендовски со појавата со секој нов стил нивната архитектура на западот редовно евулуира па дури во барокот и до момент на китење со гротесни скулптури по крововите ајде така речи демони чија смисла не мие баш јасна, иако имам чуено дека тоа се должи на празноверие со кое сакаат да ги изгонат паднатите духови, малку преиронично но ете и тоа се вади како оправдување... но и самите католици се на чисто дека претерано се опуштиле и во недоглед ја развлекле симболиката и канонските правила кои посебно ги востановувале за сопстевните архитектонски изрази  www.catholicliturgy.com/index.cfm/FuseAction/ArticleText/Index/65/SubIndex/116/ArticleIndex/24
нели веќе за ова идејно решение имавме разврзано муабет, мислам дека сеуште не е конечен овој муабет, а за тоа дека загребчани вака или онака ќе ја условат естетски градбата тоа не ми се верува, веќе има стари Православни Цркви во сред град па така нема потреба од некакви опструкции...
This page was generated in 0.359 seconds.
